hi all, would this idle learn procedure also help the extreme start up idle with new tps and iac sensors? recently replaced the iac and tps on my fathers vt ls1 commodore as their were codes coming up for both those sensors and including knock sensors (knock sensors not the problem here tho) and after replacing them we had started the car to make sure everything was working and we hadn't done something wrong, but as it started it have revved up to 2000rpm, for reference before replacing the stated sensors it would rev to 1100 rpm then drop to about 800-900rpm straight after. we didnt take to much notice we just thought new sensors, new start up. but summed up it got worse making use switch back to the oem sensors which brung the idle start up down to that 1100 to 800-900 rpm. then only recently we thought cos we bought ebay "brand" sensors there was issue, so week ago got GOSS brand sensors (tps and iac) and exact same high revving issue as before with the new goss sensors has occured, again making us this time only re-using the oem tps sensor which stops the high revving on start up.
sorry for the long comment, but feel if i dont give enough info none of yous are gonna know what im on about.
Were they OEM, or after market ones ?
I purchased a aftermarket IAC & TPS unit, and the car was all over the place,
I reset the idle with a scanner, and it still idled higher than normal,
What I noticed is that the car was driving by itself at approx. 60 km/h,
Which means it was struggling to slow down when you apply the brakes,
So put the original ones back in and it was sort of ok.
So I went to the wreckers and got a pair (IAC & TPS) off the same car,
Cleaned the IAC unit,
Installed them, and the car runs ok,
I did do the relearn with the scan tool, and its been ok since.
