idle problems. won't sit at a constant idle.
macksvt
vt
hey
i just picked up a 93 mdl vr sedan, $500. had a manual conversion about a year ago. in allrite nic..
the car will not sit at a constant idle. When i start the car it sits around 1500rpm, if i give it a slight rev it may stick at 2000rmp and slowly make its way back to 1500rpm.
same situation but it might stick at around 1800rpm, then slowly make its way down.
i added a return spring to snap back the throttle and im convinced that the cable is not sticking.
what else could be causing the problem ?
also the engine light on the dash is on. although the car runs beautfully besides the rough idle.
thanks
-ToM-
Bow Down to the Emperor!
SA
VR Exec [EMPIR3]
VR should idle around 700-900rpm.
Some things that it could be:
IAC valve in throttle body stuffed.
tight throttle cable
bad earthing/loom
im sure some other people will have some ideas
If the engine is throwing codes, you should be checking them
speed_freak
33
VS Executive 3.8 Eco
ive got a leaky air intake caused from a terrible seal with the air intake piping that causes irregular rpm
macksvt
vt
hey dude
how do i check what error codes im getting ?
im looking all over the forums buit i cant seem to find out how to check the codes ??
thanks
