Idler pulley noise (Ecotec)
VYMAD
SILVERFOX
BUNDABERG Q
VY EXECUTIVE S2
I know that it's possible to squirt some Inox or similar stuff into the noisy idler pulleys which I have done, however this tends to dry out rather quickly. What are your thoughts on injecting a small amount of high temp grease into these?
I thought this might last a bit longer. Or would it thin down too much with the engine heat and spray grease on the surrounding areas/serpentine belt. Cheers.
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
Why not just replace the pulley? They're less than $30 each i think from Holden and problem solved. Saves messing around with grease and such.
VYMAD
SILVERFOX
BUNDABERG Q
VY EXECUTIVE S2
Well I will replace them, but in the meantime, as funds are low I would like to lube them up. It's just that I've only read about using spray lubricant for this and thought grease may be better.
I will replace them when I can because I like to keep everything in tip top condition, as said, it's just for a while until I can replace.
edals
Dont go and be the only ecotec out that that does not have the same rattle as everyone else lol
Any high temp grease should be fine, cant hurt to try is only a bit of grease after all.
Know what you mean with low funds lol, i could buy a few of the bearings from the part but not complete lol
someguy360
The Shed
Various
I used a quarter of a can of silicon spray from Repco
Been over a month now of a nice quiet pully :)
VYMAD
SILVERFOX
BUNDABERG Q
VY EXECUTIVE S2
Thanks for replies, guys. Just got to invent something that will squirt a thin stream of grease into the small space. I thought about using a medicine syringe with a small tube attached to the end, so that it will inject the grease right inside to the area where the bearings are. I'll let yas know how it goes.
wrx884
WA's ASR Rep
39
VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
silicon spray will b ur best temp fix as its oil based so shouldnt dry as quick but saying that its only a temp fix till u get ur pullies replaced. i bought a pack of all 3 pullies from ebay 4 $60 and fitted them myself easy as.
VYMAD
SILVERFOX
BUNDABERG Q
VY EXECUTIVE S2
By all three pulleys, do you mean the tensioner pulley as well? Also with 135,000 k's on the clock, is it a requirement to replace the tensioner pulley when replacing the belt?
EDIT: tensioner pulley arm?
VS_Pete
Donating Member
As far as I know my tensioner has never been replaced 215000k.
I put a new belt on the other day and could hardly get it on the tensioner is sweet.
Cheers Pete.
EDGE3
NEWCASTLE
1997 VS COMMODORE,1996 GTS-R COMMODORE
Just turn up the stereo that seems to work
