Idling issue VN S1
wagonist
VP Executive Sedan
Unfortunately, this is one of those intermittent problems:bang:
Sometimes, the car won't increase the idle when the A/C is on, & sometimes it will idle high after I turn the A/C off.
Any ideas on where to start looking for a fix?
I'm guessing the ECU isn't getting a correct A/C signal.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
IAC valve on the throttlebody may need a good clean out.TPS may be on the way out or ecu.do you get any error codes done a code check
wagonist
VP Executive Sedan
Gave the IAC & throttle body a good clean out.
No fault codes:bang:
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
did you take the throttlebody off and pull out the iac and clean it with carby cleaner or just spray it in like you said in that other thread
wagonist
VP Executive Sedan
The car I'm talking about here is a mate's.
The throttle body & IAC were removed.
We weren't game to just spray it through after what happened to my VN.
