Idling
CBHuskie
50
VF Evoke 2015
Just looking for some knowledge
1. Does anyone use a ODB device on a VF Evoke and if so can you recommend good software/app for this?
2. When sitting idle the idle of the car will slightly fluctuate about 100 to 200 rpm.
Any ideas on what could cause this?
Has not effect on the running of the car just have never had this with any other car before.
Cheers to all and appreciate any responses.
Clay1391
Warragul
Ssv redline
1. I use an obd dongle on my VF redline just to clear codes. Cost me 30$ roughly.
2. Mines a V8 and can tell when the fuel has been really bad. Idles rough and is very inconsistent. That's just the nature of how bad our fuel is here, 98 isn't created equal and each servo has different fuel on the day.
Milo 6.0
44
perth
2013 vf ssv wagon/2009 fg xr6t(daily
Is the throttle body clean,clean air filter? for a start.
Suami
45
2017 SSV Redline
The infamous V6 wobbles....got a 2010 VE and they eat Throttle bodies and position sensors for breakfast. Done 240000 kms and changed her twice.
May just be a dirty butterfly plate on the throttle body; (very common) but the fluctuations from my experience are usually that.
Not sure how true it is; but I was told by the workshop that did the timing chain on my VE (yes you can possibly look forward to that as well) that they ran the same engines through the VF 6s as they did the VE.
Good luck with it...
Suami
45
2017 SSV Redline
Oh and if you get the “stability control” fault show up in the dash; get a few hundred ready for the throttle body and position sensor.....
Suami
45
2017 SSV Redline
Also clean your MAF sensor; it can be as simple as that...
Milo 6.0
44
perth
especially if you run a k and n,they can draw oil onto the maf sensor.
going by the replies it seems common lol
Suami
45
2017 SSV Redline
Exactly; the carbon
Just run any air filter through them and problem is the same....Mine is stock and the amount of MAF sensor cleaner cans I have gone through is nuts...personally I would not (can’t now anyway) ever buy a Holden V6
panhead
NSW Central Coast
Cars
Yeah a lot of people over oil their K&N's.
I'd oil mine and let them sit all day and overnight to let the oil run out before reinstalling them.
CBHuskie
50
VF Evoke 2015
Thanks mate , appreciate it
Will look into it
