if you had 5grand to spend on vx ss...
johnvtls1
Melton,Victoria
E92 BWM 335I
1 x ECU - Flash scan reprogram – MAFLESS tune
1 x Set of Higgins CNC ported cylinder heads (changeover of course)
1 x ARP high performance head bolt kit
1 x performance camshaft.
1 x performance matched valve springs.
Double row timing chain upgrade (recommended, particularly on older motors)
should give you around 390 kws at the flywheel with some change out of 5 grand
hope this helps:thumbsup:
i dont see how u can get heads and cam for less then 5 grand. The only way is if you do all the work yourself. Tune alone will cost $1000, cam and srings another $1000, Heads dunno much about but gotta be at least $1500+ for some decent higgins heads.
black as
I have 2 cars VZ sv8 6 litre and VU ute 5.7 litre
check out this link :thumbsup:
HPF - LS1G4S-390 Head & Cam Package
Part No.
LS1G4S390
Make
Holden
Model
Holden 5.7l LS1
Power
390kw
Price
$5,599
Enquire
Contact Form
Holden - Holden 5.7l LS1 - LS1G4S-390 Head & Cam Package
PACKAGE INCLUDES:
1 x Set of Higgins CNC ported cylinder heads (changeover)
2 x Cometic MLS head gaskets
1 x HP-F performance camshaft. (Selected specific to customer requirements)
1 x HP-F performance matched valve springs.
5 x Genuine Coolant (litres).
1 x Before and after dyno graph.
1 x All labour to fit / dyno tune / test
MATT SAYS:
"A worth while step above the cam only upgrade, same driving experience 'cept with more power! For those that want to leave no stone unturned."
COMMENTS:
The LS1G4S 390Kw upgrade starts with our trained technician fitting a fitting a Set of Higgins Racing CNC Ported Heads and a new high performance camshaft and valve spring package that has been carefully selected by one of our sales technicians to match your driving and vehicle requirements. After all the components are fitted we custom tune your vehicle’s ECU on the dyno utilizing the latest Flash scan ECU tuning software to maximize power, torque. We complete the upgrade process by testing your vehicle on the road to make final adjustments, optimizing you vehicles performance and drivability. This is all completed in approximately 2 days and at the end of this upgrade our Sales technician will provided you with a dyno graph detailing the Power & torque increase of your vehicle.
This package offers our customers a package that will give a very noticeable increase in power and torque with that great V8 supercar sound and 390KW at the flywheel!
OPTIONS:
Double row timing chain upgrade (recommended, particularly on older motors) - $550
benjamino
needing some more undies
The Sticks, WA
VX SS 6spd + 7psi
that is a pretty sweet deal..
spoke to a bloke today about it,
reckns u can get 275ish rwkw from a fairly small cam,
(which is what im after as its my daily, in fairly mild traffic)
then ill need a clutch kit ontop of that whch is 2grand.
so 5500 all up.
if i choose to leave it at that.
:bang:
maybe i cud go on a holiday..
haha
benjamino
The Sticks, WA
VX SS 6spd + 7psi
okkkk, what about if u had only 3 grand?
the best bang for your buck power mods you could do,...
benjamino
The Sticks, WA
VX SS 6spd + 7psi
just tossing up between going all out with cam and whatnot, 5grands my limit,
or going with spending 3 and goin to bali or somethin..
Cobez
LS-EXUAL
39
2004 S2 VY SS Ute
Cam!!! If anything left over at all, OTR and tune.
stumps5L
vx ss
mate otr, Maffless tune, diff gears and clutch or cam u will be loving life for 3K
H1GHROLLR
CHEMICALLY SUPERCHARGED
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
higgins is shut down any way they stopped making stuff sorry to break the news
H1GHROLLR
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
and also that package is 390kw at the flywheel
