Ignition barrel
vsdeath
1995 VS Sedan
Hi again,
I need to recondition my ignition barrel. My favourite wrecker guy gave me the inside part in order to change it myself. He said there is a button to click somewhere around the metalic housing, once you turn the key, to release the inside bits.
I have searched everywhere around that zone and could not find that damn button..
Any help is welcome.
accentstencil
68
Eschol Park, Sydney
WH II Caprice, 5.7 2017 Captiva.
Hi again,
There is a small hole on top of the housing, insert an alan key or small drill bit in the hole. Make sure the key is in the on position to remove and to install.
vsdeath
1995 VS Sedan
Found it. Thanks!
vsdeath
1995 VS Sedan
Cant get the barrel to move more than half a mil.. Do I have to pull really hard or did I miss something..
accentstencil
68
Eschol Park, Sydney
From memory it should come out easy. Often the barrels need replacing because parts break off inside causing problems, maybe a broken part is stopping it from coming out. I'd try a little more force.
vsdeath
1995 VS Sedan
The part that snapped off was the end bit.. the one that goes inside that black plastic swich cylender. So I doubt there would be anything in the way at this stage.. Maybe I should ask a specialist to do it for me.
accentstencil
68
Eschol Park, Sydney
Do you have the key in the on position?
vsdeath
1995 VS Sedan
Well I suppose.. It's the only position where it seems to be in phase with the hole. So not the first click but the second.
accentstencil
68
Eschol Park, Sydney
Sounds right. I don't know what could be stopping it.
OzJD
Bankstown, NSW
jeltel.com.au
2010 Holden Caprice V II (V8)
I just did mine, was stuck really good, just pull harder. make sure the button keeps in, and pull more (and yes, key needs to be in ON position)
