Ignition Coil on 304 5L
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by jgtoranalc, Apr 7, 2013.
  1. jgtoranalc
    jgtoranalc Member
    Adelaide, SA
    Holden Statesman VR HSV 5L, Holden Torana LC
    Now I tested my ignition coil and it was out of specs but when I went to buy one from Sprints they said to me it was the wrong type fitted to it...
    now the coil on the right was the one fitted and the coil on the left is the one they said is supposed to be fitted.... does it really matter?
    also do I have to connect the condenser to the new coil?
  2. juiceie vh sle
    juiceie vh sle Member
    roxby downs
    VH SL/E..VF2 redline W375.. 200 series landcruiser
    they do the same thing the new one is just a smaller more reliable design. my VN V8 had the old type on it but i got the new style one when i stroked the motor and all runs sweet
  3. someguy360
    someguy360 Well-Known Member
    Adelaide Hills
    +1
    I just moved from the large traditional design to the smaller newer design.
    As said above, more reliable and easier to access etc
  4. BottleFedVS
    BottleFedVS Member
    Around WA
    VS Calais 5.0L & 80 Series Landcruiser
    I use the smaller design coil as from the factory on my missus VR & my VS.
    However to allow more room I have moved them to the Left hand (passenger) side inner guard as it is easier to get to & get my hand down the back of the motor.
  5. 304runner
    304runner ( .Y. )
    Central Coast NSW
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    I have used both, they work the same...
  6. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    You should use the one they recommended, which is the model also recommended by Holden. Why would you use an older model oil-filled coil that was not designed for modern ignition systems? The "condenser" - if that's what it is - is used to suppress radio interference. I've always fitted them, but if you're not interested in the quality of your radio reception then omit it.
