B
bucksta
Guest
my vr has a problem starting , both keys lock up when trying to start, both keys have no problem opening the doors, how do isolate the faulty part without spending a fortune on a new ignition and key assy.
Shaggerz Wrote:The key's coding is contained in the body control module underneath the dash. It matches to a small chip in the key itself which is read when you insert the key via a metal ring around the outside of the ignition barrel which is known as the key reader. Try leaving the key in the ignition and turned on for an hour and a half, then try and start the car. If it starts, then the BCM is unable to read the key. If you have a second key and this one does not work either, then the key reader is probably faulty.
If these cars are autos then it may also be the auto trans inhibitor switch out of adjustment.
