Ruben Filippus
- Nov 25, 2018
- 20
- 1
- 3
- Age
- 46
- Location
- Namibia
- Holden adventra cx8
I checked that key reader slip ring with continuity check to that wire from BCM to the ring but its give signal. The remote control can't even do anything even if I want to unlocking or locking the doors from outside. I even put a new battery but nothing. The problem I did is this that after I brake the barrel I was driving without the key touching that ring.i was only pressing unlocking button than starting the car with screw driver putting it in that black igination switch. Later than I see the car is no longer start. Fuel and spark are all good but it's only going off after few seconds and if try to prevent the fuel pedal than it giving back fire in the engine like it starving fuelSurely you checked all the fuses yeah?
If the key is sending a signal but the car wont unlock or register, you probably got a key receiver and/or key reader slip ring fault.
If the key, key receiver and key reader slip ring is good, ECM, BCM, PIM issues.
