immobilizer fail
C-man
Sunshine coast Qld.
2006 SS Thunder Ute 6ltr V8 manual
sometimes nothing happens (silent) when I turn the key,
then I try again and it starts but I get the "immobilizer fail" warning
It is also telling me it is time for my 160K servace (if that is related)
Fu Manchu
WA.
Have you changed the battery in the key?
Capsule
Brisbane, QLD
MY09 VE Omega
The transponder chip in the key is passive, it has nothing to do with the remote battery.
Looks more like a computer related issue. How fresh is the car battery?
krusing
Melbourne, Bayside
When I messing around with my replacement Key a while ago, I had the similar situation with the "immobilizer fail" displaying,
that is where the RFID unit is not reading the chip [that is in the Key Head]
As I had to program it in, to stop that from displaying.
There is 2 stages of RFID in VE's
  1. Is the ID Chip in the Key Head [Non Flip Head, and Flip Key Heads]
  2. Is the Remote side of it, to unlock and lock the car, and all the other smart stuff it does in the background, based on your level of vehicle variant.
Based on that, there is 2 Area's of the BCM that the key needs to be programming to make it work.
But with your situation,
Does it happen with Both Keys [assuming you have 2 keys], if it does, I am guessing its the RFID receiver could be at fault, which is located around the ignition switch by memory.
or
If its only happening on one Key, I am guessing chip could be faulty.
That is where you would need to get a new Key Head, get the Key cut [that's if its a non flip Key],
but if you have a flip Key, get a flip Key Head, you can swap the Key Blade that will/could save you $44 > $80 depending where you go.
Either way, the new RFID chip will need to be programed into the 2 Area's of the BMC,
But your existing Remote still should work.
I had a complete opposite situation before purchasing my replacement Key
The Key would work, and the car would start,
But the remote unit failed, and it wasn't the battery, as I tried 2 new Batteries,
Hence the reason I purchased a new key and had the similar issue.
As for the service, it could be co-incidental, unless it does need a service,
How many K's has your car done ?
On the other had, a immobiliser issue will not activate the MIL lamp, so I would get your car scanned to see what it is doing, or in this case Not doing.
then take it from there.
Fu Manchu
WA.
Just so happens I can get a photo of the RFID receiver.
It’s held in with a single screw and the loom plugs into the back of it.
C-man
Sunshine coast Qld.
Thanks for all the help guys, I guess I will start by getting my other key and see how it goes, also check the battery as it did sound a little weak one time.
C-man
Sunshine coast Qld.
I leave the key in the ignition while parked in my garage, does that matter?
The key has the locking buttons on one side.
I found the other key, but it does not fit into the ignition for some uknown reason
It does not do it every time, and seems to have stopped now, when it did do it it would not start and took a couple of times, then it did start.
The ute has done 160Ks and is correctly due for service, I will do the oil and filter, and cold air filter clean. Not sure what else is needed, will look it up.
krusing
Melbourne, Bayside
Maybe replace the Fuel filter,
and check the Cabin Filter, as that is one item that gets forgotten about.
lout
60
Langwarrin Victoria
lol time to reduce your medication
neither of these will cause a no crank scenario
krusing
Melbourne, Bayside
Edited !
The op said -
"The ute has done 160Ks and is correctly due for service, I will do the oil and filter, and cold air filter clean. Not sure what else is needed, will look it up. "
Just out of courtesy, I though I would just mention a couple things that are usually forgotten when servicing.
