Immobilizer
Doug whiley
56
Wonthaggi vic
Vt acclaim
Does anyone know how to disable an immobilizer on a VR (no im not stealing one, it's mine) my VR is permanently immobilized. I've tried taking the engine fuse out, and disconnecting the battery. I can override the immobilizer by turning the key to ON, waiting 45min, then turning it to start. But this makes my VR very unsuitable for bank jobs.
vs-lover
VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
If I'm correct you'll need a Memcal with no VAT included to override that "very secure" security feature LOL
losh1971
North Tas
VE Series I SS Ute
There used to be a bloke on Gumtree who disables the VATS in the BCM. He used to charge $45 - $50 IIRC. Mine has been disabled in the BCM but it does throw a code 31 now that won't go away, even with my VATS disabled memcal.
woteva
NEED 4 SPEED
Adelaide S.A.
Check the contact ring is good around the key hole.
vs-lover
Good spotting Wot !
Yes those readers around the Key hole can be problematic and you don't even know that it's fractured internally.
vs-lover
I've always been of the opinion that when you mess around with factory systems they'll always throw a spanner into the works as a repay favour LOL !!
losh1971
North Tas
VE Series I SS Ute
Good spotting Wot !
Doesn't the ring stop it cranking rather than activate or disable VATS? I had a VATS problem a few years ago when fitting a new memcal, it cranked but wouldn't fire. I have a problem with mine now that the key has worn down that it stops it from cranking, every now and then.
