- Apr 15, 2006
- 22,487
- 19,942
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VX Calais II L67
Anything to share
There is a ridge, it's a cast defect. Nothing critical.^ is that right side chamber of the second head OK as the little defect in the lower righ side looks to have sharp edges? will they be an issue causing hot spots that could lead to unintended ignition issues?
About what car you got the boy....About?
This has my eye twitchingEnded up getting the 2nd head on, then realized I've swapped the head around...
Did the oil change on the boys beemer and thought I might as well get the LIM bolted on, but it's completely filthy so chucked in the little parts cleaner instead
The gasket surfaces cleaned up ok but there is a bit of corrosion on the faces around the coolant ports.
Will give it a bit more of a clean around the injector ports in the morning and it can go back on even though it's still a bit filthy on the outside.
View attachment 225136View attachment 225136
As long as all the important bits are clean and internal surfaces.
