VK SL 3800
I've always liked these cars, and I knew a guy who swapped all the WRX STI driveline parts into his low spec Impreza, as far as I remember it wasn't too hard, basically just changed it all over as they were basically the same. Of course using a forester as a donor may make things a bit harder.
I guess you could swap the wiring looms over, but i'm not too sure how they work in Subies.
Are you going to keep the stock Impreza look, keep it a sleeper and go a front mount cooler (maybe stealth black), or leave it as top mount and get the bonnet and kit from a WRX?
The forester is based of an impreza so im hoping most parts will direct swap, the looms are pretty similar so im going to do a whole loom swap to save rewiring it. Ive got a spare bonnet for it so ill just make a hack job scoop fitment. On a bit of a budget so ill leave it all std until later.
