Model: Jan 94 VR Colour: Gun Metal Grey Bodykit: None Engine Type: 3.8L Engine Mods: None Power: Untested Exhaust: Loud? Gearbox: Auto Diff: LSD Brakes: bad Suspension: Lowered Peddars Wheels/Tyres: Standard Interior: Standard Other Mods: Dented Stereo: none The Plan As you can see below, the car has not seen much love lately. Its been crashed, scratched, manky and even has been 'touched up' by a drunk dude with a spray can. I intend to show the car some much deserved love, restoring it to its former glory. As surprised as you may be, the motor and box are running fine but need a few changes here or there. To Do List Clean interior & motor Replace Tail lights Remove Pod (Hot air) Filter Change Battery Repair Dash & Glove Box (inc repainting) Inspect & Repair brakes Replace Speedometer Replace tyres Replace doors and damaged gaurds http://i28.photobucket.com/albums/c243/mccabe1100/The VR Project/DSCF7861.jpg
well i can only hope.. thanks guys, ill let you know how i go, keep this one in your favourites though..
Bit of an update at the moment, tried pulling the rotor off, didnt work so pulled the whole lot apart, i guess maybe i should clean everything up?
So i finally got to work on the vr again, this time it entailed the art of body restoration, i have started repairing the damaged gaurd, sanding it back and bogging it. Also started painting the dash, finished painting the cluster surround. Also started sanding the boot lid and roof in an attempt to prep for painting, but got over it and went back to bogging the gaurd (wasnt set properly and i attempted to sand it) Will get some pictures up for you guys soon.
