Hi everyone, I won't bore you too much so i'll get to the point.
I have an 2011 E3 GTS and I literally just picked it up on friday afternoon from having the following done to it. Full Difillipo 3" system with 1-7/8 extractors, lifters replaced, OTR, stealth camshaft (which sure as hell isn't very stealthy!) tune and new spark plugs and leads but now my car has just died
It obviously is going to need to get back to the shop but currently the car is about 20kms or so away from it and I would like to avoid an expensive tow truck experience by at least getting the thing going and hopefully driving it a bit closer. So for those that are still reading here is what happened.......
I was in a 60km zone car in front was turning so i had to slow to about 30ish. Once i had room to pass the car i accelerated (not aggressively) as i did that there was a loud bang which seemed to come from the rear and i had no power, it spluttered for a few seconds then it seemed to be ok. Pulled into servo 20 meters down the road stopped the car had a look under couldn't see anything obviously wrong (not that i knew what i was looking for) went to start the car again and when i turned the key it just made a rapid clicking noise without turning over. Pulled the key out waited a few seconds and tried again, started fine and seemed to drive fine for the few kms down the road to the supermarket where i stopped and went in for 5-10 minutes. When i came out I started the car and it seemed fine. Drove down the road to the next place stopped for about another 5 minutes or so and once again the car started fine afterwards. I drive for another few kms where I stopped at a set of lights (i was at the front) accelerated like normal (not aggressive) but it felt sluggish so i pushed it a bit harder to get up to the 80km speed limit, all of a sudden it made a popping sound and i had no power, it started spluttering all over the place again and had no power like it was in some kind of spluttering limp mode. No matter how hard or soft i pushed the pedal it gave me the same amount of power and just made a terrible popping/spluttering noise.
I got it to the car park of a shopping centre where i turned it off hoping it would start up like it had done the last 3 times, but no
It turns over and starts but splutters to a complete stop after a second or two. It seems like after that initial bang it didn't like being pushed, a slow steady acceleration and it was ok but if you gave it a bit foot it didn't like it.
Since i got it back there has also been a strange smell not petrol and i don't think its oil but it is a chemical smell I've never smelled before, not sure if that means anything.
On the Friday when i picked it up i did give it a short aggressive zap and it felt like the car over reacted to the amount of pedal i used. Like when you floor it and it and the car takes half a second then roars into life. It made a strange noise but gave me the power and a loud roar
but didn't seem 100 percent. I just put it down to something i would have to get used to and continued my awesome driving experience on Friday.
Well if there is anyone out there that can help me get my car moving enough to get it back to the shop that would be greatly appreciated.
NOTE rain in the video is very loud so check your sound level. The louder it is the better you hear the noise though. Earbuds seem to be best. Also i noticed the Speedo says I'm doing 70kms but i was going nowhere near that probably only 40km if that!
