Increase revs on idling
trademark
VX Executive S/W
Can anyone tell me if it's easy to increase the revs of the engine at normal idle ? I have a VX, and it currently sits at about 600 rpm while idling, but I would like to take it up to about 800 rpm. Is that easily done ?
Boonz
Donating Member
35
berri, south australia
green 355 VG ute
on the throttle body there is a butterfly adjustment screw that lets more air in when idleing so just give it a slight turn while the engine is running and et it to where you want it
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
the idle speed is programmed into the PCM, it will need to be reprogrammed to change it.
If you turn the screw the only ting you will achieve is stuffing up the computer control for idle.
Rob
