Indicator problems
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Noy, May 7, 2007.
  1. Noy
    Noy New Member
    VN SS 5.0
    The indicator in my vt stopped working - the lights don't flash on and off - but the lights do work, so I dont think its a bulb or a fuse causing the problem.
    Also the cluster light doesnt "flash" either, so I have to manually use the indicator stalk at the moment.
    Any help appreciated.
    PS. Autobahn are hopeless when it comes to this!
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    Probably a stuffed flasher unit. It's in where the fuses and relays are under the steering column.
