info on error code P0111 help
Discussion in 'VE Holden Commodore (2006 - 2013)' started by SV6.07, Dec 28, 2013.
  1. SV6.07
    SV6.07 Donating Member
    Melbourne,Victoria
    2007 VE SV6 Nitrate & 2011 VE SV6 Poison Ivy
    i been having trouble with my SV6. first was throttle body codes. ( replaced with new throttle body now) then came up P2122 throttle pedal position sensor. (replaced the throttle pedal with new one now) but today got the same code again plus a new one P0111 intake air temperature sensor 1 circuit range performance bank 1 just before the code came up the car acted like i was tapping the throttle up and down a little. then into safety mode and esp and back to driving home slow again. am running out of options on what is doing this. has anyone had the same or know about the intake air sensor fault anyhelp would be great..
    thanks in advance
  2. Karl89
    Karl89 New Member
    Ve sv6 ly7
    Did u find the problem because the same thing is happening to me
  3. VS_Pete
    Click on this user name.
    SV6.07 was last seen:Nov 10, 2015
