info on temp and thermo trigger.
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by petsie, Feb 12, 2012.
  1. petsie
    petsie New Member
    St Arnaud
    vt club
    Hi guys, just seeking some help in few things with a VT V6, whats the normel driving temp sit on the dash while driveing?, what temp does the thrermos kick in as im worryed about mine as the temp sits between 1/4 and 1/2 and no thermo has started?, also where is the thermo trigger located on the motor?. I thought temp may have been cased by faulty thermostat so changed it for a new one and didnt chage a thing so thinking that the thermo switch is buggerd and no turning on. Eney way its a grate car and to good to destroy with a overheat so i came here and hope to get the help i need to get her feaver down, Thanks all and look forward to hereing from yous, Peter
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    Between 1/4 and 1/2 is normal, the fans should cut in at 104 degrees. Do both fans operate when you turn on the A/C?
  3. petsie
    petsie New Member
    St Arnaud
    vt club
    kool
    Thanks for your help, makes me happy to here thats normell, just not used off seeing a temp guage up that high, cheers.
