Injector cleaner for SIDI
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Ron Burgundy, Jul 8, 2011.
  1. Ron Burgundy
    Ron Burgundy Well-Known Member
    NSW
    VF II SS
    My car's only done 10 000 k's and I'm thinking of trying to keep the injectors clean by occasional bottle of engine cleaner. Every 10 000km's or so
    I like to use Liqui Molly products so I'm thinking of that
    Any thoughts whether it's ok running it in sidi engine and what other brands seem to work for you ?
  2. kuzman89
    kuzman89 Active Member
    vic
    VE SV6 ute
    Why not just run premium unleaded through it?
  3. Hym1e
    Hym1e New Member
    2007 VE SV6
    I agree with kuzman89. run some 98 through it. I've been told from a few people to stay away from all those additives.
  4. Ron Burgundy
    NSW
    VF II SS
    i run 98 all the time
  5. UFO
    UFO I Believe
    MY10 VE International Sportwagon SIDI 3L
    seconded.
    the next time you know you are going on a long drive, buy some good fuel and it'll do the same job when the engine gets really hot. 2 hours on the hwy will burn away whatever little crap is in there.
    but you've only done 10,000km so the chances of sludge build up already is next to nil (unless you constantly fill up with dodgy fuel).
  6. TinSnips
    Hills District, Sydney
    VF SSV Ute
    If you're running clean fuel, like BP ultimate, the injectors should be pretty clean anyway.
  7. Ron Burgundy
    NSW
    VF II SS
    Taking it to blue mountains tomorrow so I'll give it a bit :)
  8. VTProductions
    VTProductions Member
    Rowville Melbourne Vicotria
    VE BERLINA 07
    one questions should u always wait till ur fuel is near finished b4 filling up or is topping up so ur full most time bad
  9. acarmody
    acarmody Donati..Whoa Green
    VX Berlina
    Makes so difference.
  10. astroham
    astroham New Member
    Penrith
    Looking
    i was always told taht if you let your car get really empty (like when the light comes on) if you have any sludge or whayever in your tank ... thats when it will suck it up ... so i try to fill her up when shes got a 1/4 or more in it ... that way i avoid this problem ... plus i use bp ultimate anyway so yeah
  11. WogBoyz
    WogBoyz 435rkw/590rwhp
    Cairns, Qld
    08 VE SSV M6 Ute
    i run mine on bp ultimate and every 5000/6000 when i change the oil and that i put a bottle in of injector cleaner, never had any problems runs great
  12. acarmody
    VX Berlina
    Any crap in the tank shouldn't be a problem, your fuel filter should catch it. But if you let the fuel get too low, you risk the fuel pump sucking air and damaging it.
  13. wing_nut
    wing_nut Banned
    Up the Raod
    Barina with Chrome Plated grease nipples
    Put about 50mls of BioDiesel in the fuel tank when you fill it up
    It will strip any deposits off the injectors
  14. RiCeY
    RiCeY F O R U M W A R R I O R
    Australia
    VZ SV8 6spd 6.0 470rwhp
    Crap in the tank is a thing of the past. With modern plastic tanks you dont get corrosion and fuel is filtered pretty well at the pump before it goes into your tank.
    Fuel does degrade over time and lose octane rating but not over a couple of weeks.
    I always run my tank to empty and have had no issues over 170,000kms.
  15. HoldenOnn
    HoldenOnn Roll Cage Territory
    Busselton, WA
    VY Calais Series 2 HBD V6 Sedan 2004
    I always try to fill up before I hit a 1/4 tank. Topping up continuosly, or letting car get to a 1/4 tank makes no difference. As RiCeY pointed out, fuel does degrade over time but not enough to worry about in just a couple of weeks.
    Read this interesting article below. I found it while I was researching regarding fuel in tanks and how long until it affects performance etc.
    Very interesting reading. Especially for guys who have high powered or even standard cars which only get driven on weekends and have a tank of fuel last 3 or 4 months or longer;
    Does petrol/gas have a use by date, or can it be stored for years? | Answerbag
  16. Shorty33
    Shorty33 New Member
    Fly Creek, N.T.
    VE Omega sedan 3.0 2010
    HoldenOnn: thankyou for that informative link.
    I haven't run my VE (3.0 L SIDI) to dry yet, but I don't expect any trouble if I do, subject to having a full jerry-can nearby.
    I ran my VZ (3.6 L) dry several times. After putting the jerry-can in, and putting the can, etc, back in the boot, the VZ started instantly every time:
    electric fuel pumps are a great idea, I reckon.
    The theory about sludge, accumulated dust &/or condensed moisture, or whatever, has been around for a long time. But, there are two responses -
    never let your tank get low; or
    empty it completely every once in a while, so that the crud doesn't build up.
    For many years, I've worked on the "empty it completely" premise.
    The problem with the VE is that I got 840 km out of a tankful, WITHOUT running empty (Coffs Harbour to Canberra), and I like the idea of not taking a jerry-can with me on future trips. A dilemma, I suppose ...
  17. VYMAD
    VYMAD SILVERFOX
    BUNDABERG Q
    VY EXECUTIVE S2
    In the VY I always fill up when it's down to about 1/4 tank (roughly every two weeks usually)
    I only use Caltex Vortex 95 and use Nulon injector cleaner every 3,000 k's approx.
    Never had any issues with the Nulon and odomoter is on 144,000.
    This is an Ecotec, though, not SIDI.
