Injector Cleaner
wassaby
SV6
yeah cleaned the mAF sensor, holden check codes when they did the spark plugs, only code that was in there was key slip ring code which they told me its to do with where the key goes in not turningn correctly or something. Is there any information where i can check the ignition leads and do you have to take the manifold of. Also can i check for error codes my self? with out that computer thingy.
torana355
VE SERIES 2 MY11 SSV A6 in IVY GREEN
Waste of money mate!! Get the injectors cleaned professionally as that liquid crap does not clean them properly.
Grimace8
74
New Zealand v
VE sv6 2007
best injector cleaner ive found is the Nulon Total fuel system cleaner its like 20 bucks or so but works wonders, every 3 - 4 months i put it in and always run 98ron everyfill up hope this helps
Problem is with my ve sv6 it states use 91 or ethanol 85 only!
Fu Manchu
Get off your phone when you’re driving.
Western Australia
Kia Sorrento, VZ Crewman, VZ Cross 8, & ya mum.
It’s not saying only those fuels.
It’s representing the range of fuel you can use. From 91 to 98 and E10- E85 (if it states E85)
VZSSHawk
South Australia
VZ SS Ute & VF SSV Redline II
Yup, what Fu Fu said, all good to use 91, 95, 98, E10, E85.
