injector cleaning step by step???
hold-on
46
New Zealand
www.fusiongraphics.co.nz
2005 SV6
I am fairly new to tankering with my car, I have recently cleaned out trottle body but are sure injectors are very dirty as well!!!!
could some one explain how to clean them with pics???or guide to a site or link that can help. I have recently ran a very thin synth oil which my car obected too ( oil leaks and oily residue in throttle body!!!!!)
would be much appreciated!!!!!!! and a good addition for the how to section!!!!!
oh vs v6
JD
Donating Member
37
Deep South, SA
www.ccgm.au.tt
1.6L Turbo Holden Croooooooooooze
buy injector cleaner from super cheap, fill your tank up with petrol and put the cleaner in there, by the time your tanks empty they should be clean.
hako
Donating Member
81
Toowoomba SE QLD
VS11 BT1 V6
I know that with a Jaguar series 3 XJ6 (70's technology), you can remove the injectors, soak in straight Techron or other injector cleaner, wait an hour or so, and then run the Techron thru the injectors. To do this you need a fuel pump to pressurise the Techron/cleaner and a 5V power supply to fire the injectors. You run the stuff thru them till you get a nice even spray.
Dunno if anyone has tried this with modern injectors.
Harvs82
42
Glen Waverley VIC
MY08 Subaru Liberty GT-B & MY16 VF II SS Redline
I don't know if anyone else has tried this, but I recently purchased a tin of Holden Top End Cleaner, and have started to run this through my tank today. This stuff is meant to clean the injectors, as well as removing carbon, gum and other deposits within the fuel system...
Instructions for it are very specific, you must add it to 38 litres of fuel, and wash down the filler neck afterwards with petrol.
Will be interesting to see how it goes this week, hopefully I will end up with some better economy and smoother power, and of course a nice crisp idle.
Top End Cleaner is available from Holden spare parts, $17 for the tin.
TheForgotten
only human......
quarantine
www.holdenscene.com
VR EXEC
must be pretty caustic. keep us informed how it goes
