When did you have the injectors replaced and was it under “warranty” or Holden’s “goodwill” or did you pay for them to be replaced?
In any case, it’s easy to check the injector resistance and see if they are still within spec (can’t remember what ohms range is acceptable but it’s stated in the other injector related threads).
If the injector(s) are outside spec, go back to whomever replaced them and get them fixed at their cost.
And if you paid privately to replace them, I’d be contacting HCC and requesting reimbursement as injectors are a life of vehicle component.
Alternatively, you could have crap in the tank (from bad fuel) which is clogging up your injectors, so you may need the tank & lines flushed and filter/pump replaced. Could also be a ECU driver or wiring issue
Good luck with it
