injectors loose?
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by sebstenator, Dec 28, 2007.
  1. sebstenator
    sebstenator Burn
    VN SS 5.0
    i looked at my fuel injectors and i noticed they were all loose and such i dono if its ment to be that loose but i jus wanted to check. and also a mechanic checked em over and said they were leaking air at the base so they wood suck air in i dno wots caused this but any feedbak wood be sweet.
  2. kniever
    kniever Active Member
    greensy, melb
    VY II Calais L67 & VN II Calais T5 5ltr
    go to repco and you can get a couple of box's of rubber o-rings for a couple bux each and go thru and change all the o-rings on the injectors, its a very easy job to do
  3. sebstenator
    sebstenator Burn
    VN SS 5.0
