Injectors?
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Torniquet, Jul 28, 2006.
  1. Torniquet
    Torniquet New Member
    Heya im thinkin bout gettin sum bettr injectors for the VN..its a standard 6..what sort of injectors are available that give a reasonable performance gain?..
  2. 38VNIT
    38VNIT Azerium
    Inverell
    nothing
    on this topic, i know nothing about injector cleaner, if i went to supercheap what should i look for when buying injector cleaner for a vn-v6, and what kinda price...
  3. coolvxss
    coolvxss New Member
    canberra
    5sp VN Executive1988, VX SS 6sp
    There about $10 a bottle. I have used a few different brands and havnt found any difference between them. They all seem to do there job.
  4. pandaman
    pandaman Aussie Muscle Fan
    VN Berlina 5.0 A4
    No point getting bigger injectors unless there is a need for them. Standard injectors should be fine unless you do some serious mods and then a retune that requires more fuel. New standard injectors might give a performance gain if the old ones are seriously rooted, but in that case it would probably be a cheaper idea to just get them cleaned. Given how expensive the damn things are I'd suggest you'd be much better off getting an exhaust and CAI for similar money. These will give real gains for your money.
  5. Torniquet
    thanks pandaman...im a 3rd year apprentice mechannic..i just did a on-car injector service on it 2day..n got me finkin bout injectors..which i noe nuffin abt on the "after-market" side of things.
  6. Doctor Bob
    Doctor Bob Grandpa
    Retired
    RG. Colorado & Caravan
    any change in injector flow rate will require a tune, the flow rate is part of the calculations in the calibration, change it & the whole deal goes pear shaped.
    Rob
  7. yZoH
    S/E Subs, Melb
    (0.o')
    Reminds me, I should get that memcal re-tuned for my new VT 22lb injectors...
    MaT
    VN V6 injectors -17lbs/18lbs = After 16years of use take about 2lbs off.
    VT-VY V6 injectors -22lbs
    Havent even had the re-tune yet on my memcal, but it idles different, different exhaust note, an drops rubber like a cheap st.kilda hooker.
