injectors
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by mking, Aug 18, 2008.
  1. mking
    mking New Member
    Newcastle
    Bagged vs caprice sII
    Hey guys just wondering how i would go about cleaning my injectors done a search and couldnt find any thing.
    cheers
  2. DannyboyDS
    DannyboyDS Just hand me the pliers.
    VS Berlina
    really you should get them ultrasonically cleaned.
    If it was me doing it, i'd purchase the injector rebuild kit (contains seals and such) then i'd have them all hooked up to an adapted fuel rail (adapted to fit sometthing like a spray gun)
    fill the adapted fuel rail with xylene (the air compressor and spray gun etc will force this through with pressure) then use a circuit designed to pulse (a small strobe circuit will work wonders and they are easy to get and cheap) on the injectors.
    you should now have flowing xylene, actually spraying xylene, out of the injectors, let this continue untill the spray pattern appears to be good enough.
    Now strip down the injectors and use the rebuild kits.
    Refit the injectors and hope for the best I guess, Xylene is a cleaning product used in fuels allready, so it should be ok, I work with the stuff and feel safe in saying, wear gloves and don't breath it in.
  3. kopper69
    kopper69 New Member
    VRII Acclaim
    There is a company called mobile injector service, or something like that, that are really good if there is one near you. I know there are a few in QLD, not sure where youre located. They come to you and have a setup in the back of a van. Will do the lot and give you a report. Not the cheapest at $250, but that is a full set done (V6). Let me know if you want their details.
  4. -=ApheX=-
    -=ApheX=- Member
    Ya mums house!!!
    VS 3.8l Exec
    actually I wouldn't mind knowing the name of the business and contact details, cause seriously Holden charge you a stupid amount to ultrasonically clean injectors... i mean it really isn;t worth the cash wasted...
    so let us know
    cheers
  5. whitevrboi
    whitevrboi Just another white vr.
    VR Executive S2
    just curious how much does holden charge to clean injectors?
  6. -=ApheX=-
    -=ApheX=- Member
    Ya mums house!!!
    VS 3.8l Exec
    well i had been charged $600 in excess, just to have injectors removed and cleaned... for that price i would expect they would be replaced with gold plated ones!!! grrrr
  7. DannyboyDS
    VS Berlina
    did they at least do a spray pattern + flow test? with a detailed report?
  8. ephect
    ephect Donating Member
    VS Acclaim V6
    with a price of 250 for a clean, and 600 as mentioned, you should be able to purchase a new set. holden dont have them, so i've been told, but im sure an injector specialist should be able to set u up with a set..
    id much rather a brand new set, for round the same price of a clean. Then ur garrenteed to know that where the pintle rests, is not damaged (which happens over time) and seals perfectly fine.
  9. DannyboyDS
    VS Berlina
    VX injectors should fit though yeah? I bet they still sell them.
  10. VRV6BT1
    VRV6BT1 New Member
    telarah
    S1 VR V6 BT1
    I think vx injectors flow at a lesser rate, because the injector rail runs at like 3.5-4 bar where earlier rails run at around 2.5-3 bar, apparently a higher pressure in the rail with a lower injector flow rate gives a more efficient spray pattern.
  11. st3r3otyp3
    st3r3otyp3 Donating Member
    WA bruz
    VX HSV VX SS
  12. ephect
    VS Acclaim V6
    yea they do fit, and the VT-VY are all the same injector
    Correcto, but its only a 1cc flow rate lower, and with a better spray pattern i'd doubt even a dyno would be able to tell the difference. they do run at different bars, yes.. i dont know what the resultant would be, less flow? maybe, but in saying that i have a VT engine complete with VT injectors running of my original VS ecu, and i havent noticed any difference in power at all from the engine swap. so i wouldnt totally rule them out.
    im not 100% sold on reco injectors, had a bad experience, bought a set for the misses dad, yes be it an EL, but still, dropped them in, car ran like ****. ripped em out, instant improvement. ok, sent them off for a check, 1 didnt work at all (blocked) 3 where flowing at only half capacity, n only 2 worked within the specified "working range" and it was one of those sellers.. only new or very low kms ones for me
    more info..
    check one of my older posts :thumbsup: http://forums.justcommodores.com.au/794625-post3.html with a link to the injector details :D
