JMann
- Oct 19, 2021
- 6
- 1
- 3
- Age
- 47
- Location
- Australia
- VU Storm Ute 3.8l V6
Hi everyone.
Recently I have been working on my Ute. Started with the broken crap in the interior, and finally onto oil leaks. I replaced the rocker cover gaskets, the trany cooler in front of the radiator, was weeping fluid out through the radiator and over the engine, replaced that, the oil sensor etc. Flushed the cooling sytem and replaced the fluid and knock sensors (Clips disintegrated). Then after a while I noticed some oil leaking from the front and rear manifold seals. I knew the manifold gaskets needed replacing so I ordered a full upper set and injector kit and started pulling the top off.
I noticed the manifold bolts were not at the correct torque (loose) and the Loctite felt non-existent. The gaskets and seals was indeed f*@ked and the RTV still held every
thing together nicely.
The heads surface seemed ok (the case was a f*@king mess) and I stated cleaning the carbon and crap from the inlet manifold components.
Now I have the inlet manifold surface clean I find it to be corroded.
The Good side. Looks ok not awesome but ok.
The bad side.
You can see where the coolant (or lack of it) has been following along the gasket line into the intake port on the left-hand side of the image. Damn. That’s not stain that's light pits of corrosion.
So, my question is, is it stuffed or can I salvage it?
What are my options?
I thought about resurfacing it on glass or at a machine shop, but then it won’t really fit properly because of its shape and probably just fail no matter how good the finish is?
Is this a common problem? the engines done over 300 but runs well.
Anyone come across this?
I've looked at some second hand ones but they seem in worse condition
Second hand.
Regards
Mark.
The bad side.
Second hand.
Regards
Mark.
