what symptoms do you get from a dogey inlet manifold gaskets? on a vr v6 auto? shes got a miss and ive replaced or checked everything else: plugs leads coil pack dfi crank angle sensor balancer throttlebody all sensors checked and or replaced compressions all good vaccum good computer please help :bang:
Best indication is that she will lose some coolant...not much but noticeable. A VS in good condition will lose NO coolant. My fix for an intermittent or impossible to fix miss is to gap the plugs to 1.0mm instead of the recommended 1.5mm. Try it.
all the time! except for a couple of minutes on first start up in the morning when stone cold? head gasket tests ok!
