inside lights
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Archers, Jun 22, 2008.
  1. Archers
    Archers New Member
    ADELAIDE
    Ve Calais V 6ltr
    hi guys just a question, my inside lights dont come on when i open the door, they will only come on when the car is on and the doors open, the lights are the door trim lights and the roof lights. it started to happen when i changed my bcm. is that the problem? thanxs scott
  2. roger05
    roger05 New Member
    Country boy in Magil
    VT Super6 S-PACK
    Hey you might have a base model bcm in a Calais?? were the numbers on the bcm the same
  3. Archers
    Archers New Member
    ADELAIDE
    Ve Calais V 6ltr
    na it was a low i removed and replaced with a high, and i forgot i dont have an immobilizer anymore i only flashes once when i lock it and before it done it twice
  4. roger05
    roger05 New Member
    VT Super6 S-PACK
    id say that is were the prob is, those bcm's had a bad solder issue. if you have a soldering iron you could go over the circuit board and re-solder all the connections in the origional bcm this some time fixes them. But prob best of trackin another low spec from some were.
  5. Archers
    Archers New Member
    ADELAIDE
    Ve Calais V 6ltr
    where is the bcm located? thanxs for the imput
  6. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    The BCM is located up in the dash sort of above the fuse panel. It clips into place. Push the bottom of the BCM towards the front of the car to unclip it.
  7. Archers
    Archers New Member
    ADELAIDE
    Ve Calais V 6ltr
    thanxs m8 if i buy a new one high with a key it will all work sweet hey? thanxs for the help guys:thumbsup:
  8. Archers
    Archers New Member
    ADELAIDE
    Ve Calais V 6ltr
    just rang holden they said the tech 2 needs to be updated of a cost of $60 min if its straight foward? does that sound right,
  9. roger05
    roger05 New Member
    VT Super6 S-PACK
    Yeah new bcm needs to be programed to your key. $60 is nearly an hours labour that sounds a bit rough for a 10 min job, any one with a decent scan tool should be able to code it in but i don't know what the prices should be. just make sure the one you buy suits your car.
  10. accentstencil
    Eschol Park, Sydney
    Yes, the new BCM needs to be linked to the ECU.
  11. Archers
    Archers New Member
    ADELAIDE
    Ve Calais V 6ltr
    thanxs guys so i will get the tech 2 chananged, i will get them to change my speedo while there coz it reads wrong due to diff upgrade
  12. roger05
    roger05 New Member
    VT Super6 S-PACK
    you can get a speedo healer from jaycar for about 40 bucks which can be changed when ever you change the diff!!
