ok is that a blue with white trace or vice versa? and which colours come from the trans to this area? i know theres 3 from the speed sensor: Theres a Black with white stripe
Purple with white stripe and a Pink with blue stripe. where do these go on the vr loom/vp ecu so i can have a speedo again?
You are going to have to figure it out yourself some.
You will need to connect ignition switched battery voltage to the P/Blu. Doesn't matter too much where that comes from but it should be fused. I think that it's 15A.
B/W is the earth for the sensor (needs to be connected to an earth).
V/W is the signal wire for the 4L60 Hall sensor. This will have to have regulated 10 volts to it from the speedo head and will be switched to the sensor earth by the sensor as it rotates.
On a VP, the signal wire goes to the lower leftmost terminal of the middle/right plug that the instrument cluster fits over/onto. You may have to run that wire outside of the VR harness to get to that terminal.
If the clusters are the same in VR and VP, that should get you a working speedometer. If that terminal spot is filled, you can trace the wire back through the harness to find a convenient connection point. That wire is also spliced to provide signal wires to the trip computer and BCM, again on VP.
In a VP, the speed signal (from the speedo) to the ECM is a brown yellow wire, top row, 4th from the left in the rightmost connector behind the cluster. That goes to terminal A10 at the ECM. In a VP that will be a processed signal with the speed sensor signal frequency being divided by five. You may have to run another wire for that also as that won't be present in a VR harness.
As you have already been told in an earlier post, the speed signal in a VR comes from the PCM to the speedo head - actually the voltage at the speedo head is earthed through the PCM in an analogous way to the Hall sensor earthing the signal in the VP. If that signal has a different frequency between VR and VP you will have to use something like the digital speedometer adjuster to alter the frequency back. Have a look at the clusters - PCB's, terminal connections - for both the VR and the VP to see if they are the same. Even if the clusters are different, the speedo heads may be interchangeable.
