Installing Cruise Control???
Discussion in 'VY Holden Commodore (2002 - 2004)' started by holdensupporter2005, Sep 28, 2005.
  1. holdensupporter2005
    holdensupporter2005 Member
    N.E. Vic
    2011 VE SV6 II Commodore - Chlorophyll
    Hi Guys
    Just picked up my 2003 vy executive today :)
    only to notice that it doesnt have cruise control :b:
    My old VT had it and I am very use too using it.
    Just wondering what it would cost to get installed and what there is to it too install????
    any help appreciated.
    thanks
    Chris :wave:
  2. maxy0987
    maxy0987 New Member
    VY Exec S2
    my bet is that it isnt cheap, i dont know if its somethign you'd even bother putting in once youve got a car because im guessing they'd have to put in a new steering coulm that has the wiring in it for CC? i dunno dude, best bet is to call a dealer and ask in the morning
  3. Stretcher Bearer
    Stretcher Bearer A.R.N.G.
    VT2 SOCOG Exec 9C1
    ~300 + for the kit complete Allow up to 500-700 all up for a dealer fit.
    By the kit separate and see if you can get a better price.
    The loom etc is in the Column and the wiring is 'generally under the bonnet. The kit actually includes the addtional under bonnet wiring if it doesn't.
  4. Fekason
    Fekason Fekason
    Penrith NSW
    Watch Ebay!
    I have seen VY cruise control kits go for less than $200 on Ebay.
    Fitting is easy if the loom is there, which I suspect it is.
    It came standard on my VY S2 manual. I installed it on my VS S@ manual when I bought it in 1997, and the wiring was there because, I think, it had ABS.
    I expect that the loom would already be there.
  5. beenbag666
    beenbag666 Guest
    Holden quoted me $900 gen fitted on my VY. I politley told them to go stick it..
  6. holdensupporter2005
    N.E. Vic
    I got quoted $300 for the genuine kit + $150 Labour to fit it from local holden dealer.
  7. Fekason
    Fekason Fekason
    Penrith NSW
    Getting Closer to the mark!
    A kit for $300 from Holden sounds about right.
    Fitting for another $150 sounds a bit much. Took less than an hour in my VS S2, which included wiring mods for the microswitch on the clutch pedal.
    As I said, they will proably appear on Ebay again sometime for about $200 or less. Fitting should be less than $100.
    Patience will win out.
  8. Stretcher Bearer
    VT2 SOCOG Exec 9C1
    Fitting a new cruise kit at a dealer carries a 55,000 (therabouts) warranty. Sometimes with an important part fitout like this it's worth considering.
