Installing Cruise Control...
1991_Vn2nV
Gumeracha, Adelaide Hills
91 VN Berlina & 03 VY Berlina
Ok a few questions here.
At the moment I have the following parts... Cruise Control Switch Block, Module and cable with bracket. Im hoping all I need now is two switches for the brake pedal?
Now I have a Series 2 1991 model Berlina which came factory with electric windows, aerial, power mirrors. Would the wiring be there for cruise control? Apparently the plugs for switch blocks and module etc. are already there, however I have yet to look.
Does anyone have any pics of where the module is located and where the cable runs near the throttle body? Also, anyone got a pic of the plug to the cruise module?
I already have a wiring diagram for it, just wondering if I have to wire it all myself or if some of it should already be there?
Wiring diagram that I found on this site:
12000
you only got to take the instrument pannel which isnt hard and connect the wire for the speed sensor and the cruise control lights and put the dash back in after checking it first and do the brake switches and the cruise control switches and run the wires out to the engine bay and connect them to the module not sure how long it will take let me know how you go
STEALTHY™
So Wet For You!
SA - The Roadworks State
I don't have any pics, but i can get some later tonight, and maybe upload them tomorrow (my comp at home is ****ed)
The module sits under the Airbox (on its side along the inside of the strut tower) and the cable runs along there, then bends up and goes behind and then around the Aircon setup to the Accelerator cable.
This is on a VP with cruise, so i assume the VN is the same as the V8 models are the same.
88GreenVN
Next Exit Left
60
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
Here are some pics for location....
STEALTHY™
So Wet For You!
Lucky he had pics, cause i forgot the cord to plug the camera into the computer, and this dodgy work comp doesn't have a thing for an SD card, only a USB
Pics are the same as my VP anyway.
88GreenVN
Next Exit Left
60
Surprise, Arizona
Hey Note my Factory Cold Air Intake on the Wagon!!
35
Cairns, QLD
VS S Pack Ute
:) I was about to start this exact same thread.......
Anyway, brake switches? How do you fit them? And what sort of switch would be required? I was sorta thinking since the cruise loom is already in there and as the brake already has a coupla switchs on it for lights etc that it would already be set up...just a matter of hooking in switchbank and module...
am i way off base with that?
88GreenVN
Next Exit Left
60
Surprise, Arizona
If you have 2 switches on the brake then one is most likely the cruise switch. The Cruise loom has a grey 2 pronge connector to plug onto one of them.
