installing extractors
NV-VN
Ford Xe
hey guys not specific enough in other posts
im trying to dismantle the drivers side manifold but having trouble. i know i have to take off the p/s rack but to undo the bolts im trying to take off the steel coolant pipe and cant undo the bolt from the back where engine crane thingy is
how do i go about this the easiest way?
cheers
Coast_Calais
sick of the idiots here
gone
varies
Which bolt specifically? (pics would help)
The Coolant hose has three (Rear through manifold, mid through manifold with dipstick, front into block under tensioner pulley assembly)
The lifting point doesn't need to be removed if i remember correctly...
NV-VN
Ford Xe
well ive undone the 2 bolts that go to the manifold. and ehind the motor theres a 17mm bolt that holds the coolant pipe.. because the coolant pipe isnt coming off and i cant get to the manifold bolts. im stuck
