installing sound system
Discussion in 'VY Holden Commodore (2002 - 2004)' started by Timmos, Aug 18, 2008.
  1. Timmos
    Timmos New Member
    Kellyville
    10' VE SSV
    I've just gone and bought myself a few goodies from JB. before i attempt to install my sound system alone I'm wondering if anyone could help out.
    1) How do i get above the dash where the tweaters off.
    2) The doors, i assume there are just screws all around the edges
    3) Amp Power cable. Easiest to run from the drivers side?
    Thanks in advance.
  2. johnvtls1
    johnvtls1 New Member
    Melton,Victoria
    E92 BWM 335I
    1. theres screws there in beween the crack thingies. i think theres 2?
    2. its a few screws not hard, try it and u should have them off within 15 minutes
    3. and yes run them down the drivers side, much eaiser then removing the console etc
  3. Lumps of cheese
    Lumps of cheese welcome to the machine
    Warrnambool
    83 vh sle, 4x4 hilux, 03 monaro, 07 nightrain
  4. SAV_117
    SAV_117 Donating Member
    VY Lumina
    just a question when i put an amp in a VT it was easier to go through passenger is the vy diff??? i have a vy btw just wanting to know for future reference
  5. TMM
    TMM OEM+
    VIC
    VY Berlina S2
    Most people with Auto VY's run the cable through the Clutch cable grommet and up the driver side.
  6. bomner12
    bomner12 New Member
    nsw
    vt ss ls1
    power wire
    where would be the best place to run the power wire to get inside the cabin if its manual
  7. cpbait
    cpbait New Member
    vy ss commodore 5.7ltr
    mines an auto vy and i went through the main harness grommit on the passenger side, bit of a pain, but looks nice and factory as i put it inside conduit wrapping, there is also a small whole(may have a blank grommit, mine didn't though) just below the main harness grommit on the passenger side, would be an easier way( i noticed it after i fought with the main harness grommit), both of them come into the cabin just below the glovebox and you can see when you remove the kick panel under the glove box on l/h side. thats how i went down the l/h side of the vehicle underneath the trims and behind the rear seats and into the boot under the boot carpet, i put the whole of the power cable inside conduit wrapping, to eliminate potential interference(had this problem on my vk, i know different cars, but a good way to make sure), good luck, hope this helps all.
  8. Timmos
    Timmos New Member
    Kellyville
    10' VE SSV
    Thanks for the help!
    I finally finished the installation, whopping job but great results!!
    Went and bought an MTX Hi-Low converter, could not be happier with the sound.
    For the stock tweeters i actually left them in there, they really don't sound terrible, the mid tones go well with the hi-end tweeters from the splits.
    Getting the doors off was an absolute mission and a half, the clip inside the window winder was near impossible to get off... would of taken 30 seconds if i had the tools.
    I ran the power cables down the drivers side and put the Hi-Low converter just under the glove box. didn't want to risk crossing power with signal.
  9. STOKESY@DBFINNISHING
    STOKESY@DBFINNISHING New Member
    Parra hills west
    Vt commodore
    Hey mate I'm really struggling tryen to get the window winder handle off my doors got any tips mate
