Installing swaybars
Discussion in 'VE Holden Commodore (2006 - 2013)' started by RUF-60L, Aug 13, 2011.
  1. RUF-60L
    RUF-60L Donating Member
    2008 VE SS
    Is this an easy DIY job on a VE???
  2. Tommo_27
    Tommo_27 Donating Member
    VE SSV
    I think the rear will be. Just have to unbolt your rear mufflers to get the bar out. Havn't had to good a look. I plan to do it myself when i get around to it.
    I had the front done for me. You have to drop the K frame. Don't know how hard it is but i couldnt be bother so got pedders to do it for me.
  3. shane_3800
    shane_3800 Active Member
    places
    vr commo
    no very hard on ve in the front
  4. RUF-60L
    2008 VE SS
    Yeah we got the rear in just unbolted the exhaust to drop it enough to the bar out/in. Front looks difficult so we didn't try it
  5. bigjim92
    bigjim92 Active Member
    2016 VF SSVR
    I never had to unbolt the exhaust to change my rear sway bar...
  6. RUF-60L
    2008 VE SS
    3" pipe kinda gets in the way ;)
  7. -vkhg
    -vkhg New Member
    2005 VZ SS
    will changing the sway bar reduce the f#cking axle tramp like donkey kick burnout rejecting **** that happens when im tryina get sideways? if so, what sizes have people gone etc? (im not very mechanical.. ha)
  8. TinSnips
    Hills District, Sydney
    VF SSV Ute
    nope. You need the replacement sub-frame bushes that fill the void to help with that - higher-damping shocks will help also. Sway bars keep the body roll through corners in check and keep the weight more evenly distributed.
  9. bonners
    bonners New Member
    Sting SV Black Edition Tourer
    A mate works for Pedders. Very hard and time consuming (ie lots of labour costs) to do front. rear is very easy as I understand it
    As for the above post, Diff bush will help also and Pedders also now stock a gearleaver bush that tightens up that whole area
  10. -vkhg
    -vkhg New Member
    2005 VZ SS
    tin and bonners. expensive to do this ? its lowerd on kings with monroe gt sports and that helped a bit but i want it stiffer!!
  11. greenacc
    greenacc Searching for the billion
    VE Berlina
    uh whats a Gearleaver bush ?
    -vkhg, try Viagra.
  12. bonners
    bonners New Member
    I'll get a quote for you so you know.
    The other bush has something to do with that 'cradle' the gear lever bolts to. I'll get a pic of it. It is very easy to fit apparently.
  13. Troy711
    Canberra, ACT
    2011 Mitsubishi Pajero GLS
    I've got a set of Nolathane bushes to suit factory sway bars if anyone is keen..?
  14. -vkhg
    -vkhg New Member
    2005 VZ SS
    no good, gives me two gear levers but thats it..
    cheers mate!!
