[308] installing timing gears
DANNY8
Yo Coooornflake!
37
Port Pirie, South Australia
www.kerrbrosracing.com
VK WAGZ 5.0L, GQ Patrol TD42
installing timing chain
We are building up a 308, and when we put the new cam in we didn't think to mark where the timing was or anything so we could put the cam gear back on in the right spot.
Wat do ya do to get the cam and crank gears in the correct spot to put the chain on. The cam gear has a dot embossed on it, but the crank didn't have one. Using a Rollermaster set.
We measured up the distance from keyway to keyway on the 253 and set it the same on the 308 and put the gears on.....but something just doesn't seem right about that?
DANNY8
Yo Coooornflake!
37
Here's the one on the 253 which we tried copying.
And here's the one on the 308.
Boonz
Donating Member
35
berri, south australia
green 355 VG ute
get number 1 piston on top dead, the dot on the crank gear should be on the oil pump side of the block. then turn the cam gear round to the oil pump side of the block and make sure theres 9 links between the dots
or the gold links on the chain lining up with the dots on the oil pump side of the block
Smitty
Moderator
Bayside Melbourne
GenF SV340 R8 Tourer, VK race car, ZX12R
yes
and then properly degree the cam
instructions here -
http://www.romac.com.au/Cam_Degreeing_Rollmaster.pdf
ari666
250,000 hits
ari666
250,000 hits
DANNY8
Yo Coooornflake!
37
Well it's all in and ready to start, it's got oil pressure, but was to late to start it....will give it a shot this morning, and if it's all good we'll take it out the track this arvo for a squirt.
DANNY8
Yo Coooornflake!
37
She started and runs perfect! The practice day was canceled which was a bummer....awe well, racing next weekend! :thumbsup:
