Installing towbar on VE 2008
Buttercup67
Commodore Omega VE 2008 D/F
Can I get a towbar fitted to my VE 2008 sedan that has been factory fitted with LPG. One towbar specialist I asked says it cant be done.
Shen Long
Roxby Downs
WH Caprice 5.7L
Yes it can be done
VTS5
TechJunkie
Sth.East\Melb
VE OMEGA 3.6L Dual Fuel
That "Specialist " is dead wrong.
I have exactly the same car,bought the bar waiting for suitable time to bolt it..
krusing
Melbourne, Bayside
What load of BS,
Probably does want to do the job,
Name him, And shame him.
Possibly has TOO MUCH money.
Shen Long
Roxby Downs
WH Caprice 5.7L
Same here, I've got factory LPG in my Omega MY9.5, although it doesn't have a towbar fitted yet, I have got a 2Tonne towbar just waiting to be installed.
You may need to change your rear bumper bar & find one with a towbar cut out, otherwise, you may need to use a Stanley knife or something similar a make a DIY towbar hole in the rear bar.
P.S.
I've also seen many factory LPG VE's with towbar's driving around
Shen Long
Roxby Downs
WH Caprice 5.7L
The specialist that you called was probably referring to a Hayman Reese towbar (or some other aftermarket type towbar), these use different mounting points & the LPG tank mounting points interfere (to some degree) with the Hayman Reese towbar mounting points - But you can use any factory type towbar to get around this
I had one specialist tell me the same thing a little while back
