Installing Walbro 500 intank fuel pump
v8commodore
australia
vx ss
Hi guys have the vx ss commodore gonna order a walbro fuel pump. haven't installed one before is it just a direct replacement for the standard pump I do know I have to splice the wires for the extension. Any tricky bits I need to know in removing the fuel tank and installing the pump. I know how to remove the clips on end of the lines. Thanks
shaun001
perth wa
vt clubby
make sure you have under half a tank when you pull the pump out also on some walbro pumps the positive and negative are in different positions don t trust red and black as pos and neg double check the markings on pump and instead of splicing wires i pick the pins out of the factory plug cut them off then crimp and solder them on to the new fuel pump plug and clip them back in the factory plug
