instructions on getting too / removing memcal on vs?
pillzor
VS executive
i ask because i ripped a couple out at the wreckers today and they only way i could get too them was mangling things with a hammer.... haha , obviously when its time too upgrade mine i will need a more gentle approach so has anyone got a guide too getting too the memcal?
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
so its you that kills all the ecu's at the wreckers LOL do you mean the security panel over the ecu or getting it out the ecu there should be 2 screws on the ecu to remove the cover .as for the security panel if you have one you need to drill out the rivots at the bottom of the panel which is a mission they are super hard drill slow or you will melt drill bit afdter drill bit.
ephect
Donating Member
VS Acclaim V6
pillzor
VS executive
the problems not getting the box or extracting the ecu from the box, its all the bloody work getting too thebox in the first place . ( for the record i didnt kill any ecu`s :p)
pillzor
VS executive
i should clarify , the problem is removing the panels over the metal box .. once im there no problems.
Cobez
LS-EXUAL
2004 S2 VY SS Ute
Drill it out......Only simple way really.
pillzor
VS executive
sorry i meant the paneling ontop of the metal box , not the actual metal box.
Philthy
That dent guy
www.qbdentfree.com.au
3.0R Liberty, XC Falcon
You should be able to see one clip up under the glovebox, and then just pull it out with a bit of jiggling. I had the door sills out when I did mine that probably made it easier
Stocky: I think he is talking about the plastic kick panel itself?
