Instrument Cluster VY
Fu Manchu
WA.
And that’s why they need to be configured to suit the features and specs of the car they are going into.
Claude R
62
Camden
VF SSV Redline
Can the issue with the reverse fuel meter be resolved with the re-configuration of the cluster or does the fuel sensor need to be changed?
H
harrop.senator
Guest
When I converted the vu to a vy wiring harness the fuel gauge was originally backwards . I de pinned the fuel sender plug and swapped the wires around.
  • Like
Reactions: Lex
Claude R
62
Camden
VF SSV Redline
I wish it was that simple, no matter which way you put the wires its the same. A resistor is a resistor no matter the polarity.
H
harrop.senator
Guest
Fair enough no idea how it made my fuel gauge work correctly then.
  • Like
Reactions: Lex
Fu Manchu
WA.
It is that simple. Using the correct software or using a Tech2, the cluster is configured to suit the vehicle. This can include custom graphics on start up and matching km.
  • Like
Reactions: Lex
Claude R
62
Camden
VF SSV Redline
Yes, that is correct. You need a tech2 or software.
I haven’t been able to change the series II cluster for a series I fuel sensor. Mine still reads in reverse. Changed the resistance values in the cluster so the low resistance shows the tank is full and still shows in reverse.
Here is a dump:-
ALDL Mode: 0x1 (read configuration table) Table: 0x6
Fuel cal part # 1778397696
Sender 45 ohms = 75.0L
Sender 50 ohms = 68.0L
Sender 66 ohms = 63.0L
Sender 87 ohms = 57.0L
Sender 101 ohms = 48.0L
Sender 128 ohms = 36.0L
Sender 174 ohms = 28.0L
Sender 200 ohms = 15.0L
Sender 222 ohms = 6.0L
Sender 240 ohms = 2.0L
Tank size 75.0 L
Low petrol warn 8 L
Very Low petrol warn 2 L
