Instrument panels wont illuminate
Big_Fudge
VT Commodore
hey guys,
Just bought a VT about a week ago, with some gremlins. The entire centre console does not illuminate when driving with the headlights on. This includes the auto gear shifter, and the AC planel, the hazard light button etc. The guages (tach, speedo, and fuel) do work and so do the green/yellow light within the button for the AC and rear demister when activated. The previous owner had no idea what he was doing when installing a head unit, as it has no constant pwr, and switches modes when the headlights are turned on and off. Would the headunit wiring affect the all the other lighting?
I've checked the fuses and they seem ok. Can anyone suggest a good starting point, or give me some insight to whats wrong??
I can provide pics if required.
Located in western sydney.
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
Do your parking lights work? If not then I suggest you re-check the fuse marked "instrument illumination/park lights", top left fuse.
Big_Fudge
VT Commodore
Thanks but, the Parking lights work fine.
lout
60
Langwarrin Victoria
as you have just bought the car i would suggest multiple blown globes
VX Exec
Wilberforce NSW
VX Executive S1
Rip out the head unit, see what he's wired up and work from there.
CONROD
SOMEWHERE in the land of OZ
VZ SS THUNDER 6.0l 6 Sp
With the lights on, can you adjust the brightness of the instruments with the dimmer switch. Try this hold it to full brightness and release the dimmer switch with a flick. Had an issue once in a VY and it turned out to be the switch
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
hey guys,
Just wondering if he has wired up the complete power for the H/U to the dash/instrument illumination wire.
As said above, rip out the H/U and see how he wired it.
WHCapriceHBD
Aus
01 VX
I'd take the head unit out and see WTF the previous owner has done in there.
A housemate I knew wired a head unit in with no constant power- just accessory power. And he did it with masking tape and twisting of wires together. The constant power wire was connected to the dash illumination light circuit instead...
Sounds a lot like you've bought a car off my old housemate........
