[WA] Intake manifold Vacuum sources 304!
aidanhq
35
.;fdbvdf
olds kool and you know it.
aidanhq
35
.;fdbvdf
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
i wouldnt cause the trans canister is a controlled leak and may mess with the fuel pressure.tee into the heater vacuam or into the brake booster vacuam
aidanhq
35
.;fdbvdf
aidanhq
35
.;fdbvdf
Brett_jjj
Tamworth NSW
vs commodore
Because I'm running the turbo 400 and not electronic im getting this code..
IAT - Voltage Too Low - Auto Transmission Only -- 25
How can I trick the PCM into thinking everything is ok.?
Im not sure I get what you are trying to say.The auto transmission has nothing to do with error code 25.Error code 25 is the IAT,or Intake Air Temperature sensor..The code 25 means that the IAT sensor voltage is low.Id replace this sensor,or make sure its wiring etc is clean and connected properly..The ECU wont be able to control the engine properly without this sensor fully working.
