[VIC] Intercooled 8PSI SC14 supercharger setup
stocky
33
ITEM: SC14 supercharger, 8 PSI pulley, Intercooler pipes (no cooler) to fit a VN-VR
CONDITION: Used
PRICE:
$1000 8 PSI non intercooled.
$1400 8PSI with cooler pipes.
$1650 8PSI with cooler pipes and 6x 39 lb/hr injectors (12 months used)
DELIVERY/PICK UP INFORMATION: PICKUP ONLY. Wantirna, VIC.
To the guys interstate the PM'd me, I really cant see any easy way of shipping this stuff, unless you were to organise freight, as I really can't be bothered dealing with all that.
PAYMENT OPTIONS: COD, Direct Deposit, Funds Transfer or Other
CONTACT DETAILS: PM, reply here.
OTHER INFO: Old setup off my VN. ran great. have checked the charger rotors and they are fine, no damage at all. Piping is 3 inch, apart from one small 2.5 inch section. Piping is to suit a 600x300 intercooler, and requires no body modifications. Will fit VN fine, and should also fit a VP or VR. Pipes are sprayed in pacemaker blue. Comes will all silicone joins and clamps(possibly missing 1 or 2).
The charger is missing a small bracket off the back. It runs fine with out it, just shakes a little, but havent had any problems with it this way. If necessary, I'm sure CRS can send you the same bracket cheap.
You normally need a pod filter for this charger, or if wanted, i can throw in my modified airbox to suit it.
Also, please note the old photos. This setup does NOT include the manifolds to move the throttle body before the charger. This is the old setup seen in the engine bay photos
PICTURES:
commiedoo
vn executive vn calais
hi , stocky . pm sent .
stocky
33
bump it up. after reading another thread about a guy getting screwed over after buying a supercharger and having it posted out, i really dont want to post any of this. pickup only
Adriianz
GTS
hey mate, will this setup work on duel fuel vr v6?
stocky
33
i cant be too sure. i dont know much about gas setups, and if the piping would suit it, or how it would be tuned
Adriianz
GTS
damnit, well ill get a hold of the gas joint see what they say about it, very keen on a charger. so i guess ill get back to you tomorrow. cheers mate.
VT9C1-6
VT Exec 9C1
hi mate, mad setup you have there
my neighbours bf has a crs charged vn same style setup as the old setup u had
any chance of getting in2 contact with you to discuss the cooler piping and stuff
here is a pic of his vn's bay
looks similar to yours but the coil packs are in a different spot
thanks symn
ITS SLEEPER AS, 5 SPEED SUPRA BOX, BIGGER FUEL RAILS, INJECTORS, CAM, THROTTLE BODY, FULL CRS KIT
17UCK!
vs III commodore ute
nice set up. id buy if i didnt alreay have one lol.. free bump
t-rav
1995 VS Executive
Hey mate VERY interested ! but need to know if it'll bolt on to an ecotech as in the brackets all fitting??? (minus the pipeing).
im after the charger and injectors but dont want the piping whats the price ???
17UCK!
no wont fit on ecotec.. pipings driffernt and most probs brackets would be differnt too.. and they would need to be 100% perfect so that the belt lines up corectly.. and sum of the ecotec kits are hard to line up 100% anyway..
