Interior light electricial adjustments
Clovance
VT Executive S2, built 1999, 3.8l V6
Gday,
I already started a familiar thread but there i mentioned the wrong thing.
My question:
When im sitting in the car, my ignition is in ACCESSOIRES MODE (radio is working and cigarret slot has electricity), the interior light is in position ON but switches off automatically after about 60 minutes (i guess, did not have a look at the time). After it switched off automatically i cannot switch my interior light on again, it i like dead then.
Not until i turn the key position to ON, i can "relight" it.
Of course i can just turn the key every time it goes off, but it is enoying and i want to KNOW if there is a possibility to change that time it switches off automatically?
And No, i DONT want to buy an LED or sth, so pls dont suggest alternatives.
Thanks!
oska
vx custom 600RR
that's holdens power saving feature , it can only be set between 3 minutes and 45 minutes with a tech2
learn to live with it unless you rewire it separately from the BCM
RagingDemon
Queensland
2001 Commodore VX Acclaim
I have the exact same problem, to turn the interiot light back on i have to open the door, even when the light is switched on (not in middle) really gets anoying...
i need the light for those occations when i wanna go to the park for a chop. need the light to see what im doing... lol
Nut Kracker
Donating Member
65
Echuca Vic.
VT SS 304ci (195i)
Drivng around high as a kite. Lovely.....
Just as well you're in QLD and not where i am.
Clovance
Hey,
I found out that pressing down the thing at your door that locks and opens the doors reactivates the light, without turning the ignition key.
