THIS PROBLEM IS NOW SOLVED!!!! NO NEED TO REPLY. When I close all my doors, the interior light stays on (as well as the light next to the ignition barrel). This is annoying because now I can't use my alarm! Anyway I'm just after a bit of information, like how it works (do the buttons on the doors close a circuit when the door is open or do they open a circuit when the doors are open?). Also any other information about the system would be appreciated!
the door switches earth the light,if ya unsrew all the switches and drop them out clear of the body the light should go out,otherwise i think it has a crook module for the interior light,dont think it would have a body control module,silly question but have you made sure you have it off at the headlight switch :whistling Phillip :wax:
yeah it's been like this for weeks now and i just removed the bulbs and lock it manually. lights definitely aren't on
just went and checked the one i pulled out of my VP ute,the dome switch is on the lhs switch pod,if ya unplug it the lights should go out,i put a stato interior in it and so its now on the right hand side,and the the dimmer bit is in the bcm (i think),got a black one here if ya want it Phillip :wax:
