Interior light, turn it off
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by VR38, Feb 27, 2009.
  1. VR38
    VR38 Well-Known Member
    VB SL/E
    Does anyone know if the interior light can be set to off so it does not operate when the doors are opened?
  2. -=ApheX=-
    -=ApheX=- Member
    Ya mums house!!!
    VS 3.8l Exec
    Take the globe out would be the easiest way...
  3. Trayner
    Install a switch somewhere, and when yah want to turn the light off just flick the switch
  4. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Seeing as you have a Berlina you probably have more lights than the Queen Mary.
    Quick, cheap but dodgy way to do it is to simply push the button in and screw in a small self tapping screw. Do this to one or all doors. I've done this many times and so far haven't damaged the buttons Dodgy but it works.
    Pix attached
      File size:
      66.5 KB
      110
  5. VR38
    VB SL/E
    I might install a switch somewhere if it can't be turned off as the screw trick is good but may interfere with alarm system.
  6. Haydz
    Haydz Fasten your seatbelts
    Liverpool.Sydney,NSW
    VS UTE LS1 T56
    rofll.
    love the screw idea..
    or undo the first screw. and undo the wire thats on there and tape it.
    as they are a switching ground. so if i touches metal your light will never turn off.
  7. axemurderer101
    axemurderer101 Well-Known Member
    Albany
    VY SS
    yeah what haydz said pull the wire off the back of the switches and you will still be able to turn your interior light on with the switch on your dash
