Interiors
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by [JUDGE], Feb 21, 2007.
  1. [JUDGE]
    [JUDGE] New Member
    South australia , Adelaide
    2004 Black Vz R8 HSV Clubsport 297kw Gen IV M6
    hey i been reading round and i know with the vp u can go up to the VS with the interior like the seats (bolt right in), and the door molds and the cluster (consol) and i know tht to put the VR/Vs door molds in u need to the put the VS dash on, but with the VT cluster, will that fit on as well??? cause id love to change my interior to VT or even upwards, id like to change front & rear seats, dash, door trims..can anyone explain to me how it all works and wot doesent work thx lots
  2. [JUDGE]
    [JUDGE] New Member
    and if the u cant go the VT will the VS dash fit straight in, if i didnt bother about the heating and tht problem?
  3. 1991_Vn2nV
    1991_Vn2nV New Member
    Gumeracha, Adelaide Hills
    91 VN Berlina & 03 VY Berlina
    You have to bother about the heating/HVAC box etc... Otherwise no demister and completely illegal.
    VT is a no as it wont fit straight in, neither will the door trims or instrument cluster.
  4. [JUDGE]
    [JUDGE] New Member
    so its Vs as for the dash, will Vt door trims fit on prop with a VS cluster?
  5. 1991_Vn2nV
    The VT doors are shaped differently to VN-VS, so they wont be a perfect fit. Once again, you'd need a VT dash for VT door trims. And the VT dash is quite large so fitting it in a VN would be a heck of a job.
  6. [JUDGE]
    [JUDGE] New Member
    alright, so i guess im going Vs interior then :p any one have a step by step guide on how to replace the cluster and how to make it so the demister and air cond works prop
    ...even tho mine dont have air con now cause ive crashed..i might get it put back in later
  7. 1991_Vn2nV
    I would suggest buying a Gregory's Manual for both model cars if you're doing this, they are great help especially wiring diagrams and removing dashes and parts.
  8. [JUDGE]
    [JUDGE] New Member
    yea tht would be a good idea
  9. YMY-88U
    YMY-88U New Member
    Project VH SL/E
    to save writing up a new thread, will vs statesman seats fit into a vn, the fronts are a fairly straight fit but the rears have to little extra wide bit on them and wondering what modifications would i have to do in putting them in, i dont really wont to go and start cutting them up or has anyone done this and have any pics, cheers guys
  10. YMY-88U
    YMY-88U New Member
    Project VH SL/E
    ok well i just read another thread and it says that the vr/vs stato rear seats had different brackets to the rears in the vn, is this because of the long wheel base and yeh just wondering about that extra wrap around area on the sides
  11. azkwazere
    azkwazere Ahhh Yes, Ahhh Yes....
    .....SE Burbs
    VP 5-SPD / 24-SPD Racer Hybrid
    If you want to do the VS dash conversion... i suggest you google it as there may be a ar eally good tutoiral that i used to make it happen... fomr another car related site... that may or may not ahvea a magizine...
    Im schemeing as to how to make demister work... i have plans... if not, ill jsut get a dogy roady, big deal. I just had a look on the vic road website, even if your power windows dont work it will still pass! il lie my ass off!
    Dont waste your time with VT stuff like dashes and door trims, to differnet, may aswel get custom trims made up outa fibergalss or something.
    VN/P/R/S stuff is interchangeable, grab a Vs dash.... its hot.... The stato seats will need trimming to fit as it has the wider foams.
    VT stuff fits with modification... ive done it and its worth it...VT BErlina seats....yummy!
    aZk.
  12. azkwazere
    .....SE Burbs
    aZk.
