Intermittent cruise control failure
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Mainsman, Jan 15, 2007.
  1. Mainsman
    Mainsman New Member
    VX SS Series 2
    some time the cruise wont engage the master switch lghts the dash all the time with the word cruise but sometimes it might works and may stop or no engage at all for days the fuse is ok and i think the brake light switch is ok also any ideas or any body with that specific part of a wiring diagram and or fault with cruise control pin and or ohms readings as in being able to trace the faulty part there is only 3 ? the control module the stork control and the brake switch? thanks this is on a VX Series 11 SS sedan
  2. WAGON MAN
    WAGON MAN Gas Sleeper
    North Coast , NSW
    VX S2 Berlina Wagon with Phreddied bits.
    Have you checked your brake light globes?
    Faulty brake light globes are a common problem with the cruise control system.
    I'd suggest that you replace both the brake light globes.
