Intermittent starting problem - 2011 VE SV6 S2 Wagon
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Gaz71, Jan 19, 2019.
  1. Gaz71
    Gaz71 New Member
    Sunshine Coast QLD
    VE SV6 S2
    Hi,
    I have a problem that I can't seem to rectify, just putting it out there to see if anyone else has experienced a similar problem.
    On occasion, at random the car just wont kick over and has to be jump started. This has been happening for the last 6 months. Battery is brand new, and is charging with no problem, I have had it in to an auto elec's 3 times with no success.
    If anyone has any ideas on the subject I would be grateful
  2. commy vk
    commy vk Active Member
    South Coast Region
    commodore ve
    Hi,this sounds like a similar issue I had with my car and what I did was like you jump start (bought a jump starter,very handy when owning any car.)All my problem was the battery.
    Very annoying and always at the wrong time.
    The only thing I can think of is battery?
    Something could be left on and draining?
    Have you put a code reader on the car?
    Might come up with something.
    All leads clean and tight?
    Try the engineering mode on charging and see what it says.
    Good Luck.
  3. Gaz71
    Gaz71 New Member
    Sunshine Coast QLD
    VE SV6 S2
    Thanks,
    The battery is good, today I had literally just come from having it tested when it happened again. No codes. Recently had the software updated also.
  4. Lex
    Lex Well-Known Member
    Geelong Victoria
    VT Executive S1 V6 6 speed Auto Wagon
    How many cca's (cold cranking amps) is it?
    One of the other members had a problem with his battery. He bought it new, but was only 460 cca. Car required 750 cca to be normal. Replaced with a 750 cca and no more problems.
    I don't know if the other persons car was vf or ve. Maybe this will help you?
  5. lout
    lout Well-Known Member
    Langwarrin Victoria
    VX Executive S2
    start relay
    starter motor
    some ve had a power cable problem near the firewall from memory, but cant remember anymore about it
  6. Gaz71
    Gaz71 New Member
    Sunshine Coast QLD
    VE SV6 S2
    Thanks
    Yes I currently have a 750cca battery installed which I replaced from a 660cca.
    I have had the firewall connections checked and are ok. I will check out the relay thing and the wiring to the starter motor.
    cheers
    Lex likes this.
  7. junkart
    junkart New Member
    Wheatbelt W.A.
    WM Caprice L98
    Similar problem on WM Caprice V8 6 speed auto. It acted like starter would not kick in/turn over randomly. thought is was battery, starter or connections. Turned out to be neutral/safety start solenoid in trans, once replace never had problems since. Been nearly 12 months now.
    krusing likes this.
  8. Gaz71
    Gaz71 New Member
    Sunshine Coast QLD
    VE SV6 S2
    Thanks
    I would never have thought about something like that. How did you test it? or did you just have it replaced?
  9. junkart
    junkart New Member
    Wheatbelt W.A.
    WM Caprice L98
    Mechanic picked it up using Tech 2 scan after car was serviced which showed failing trans neutral start safety solenoid located inside the transmission. Cost me $600 for auto trans techs to do the job. Left it with them for a day.
